Strange noise/vibration
Old Feb 9, 2010 | 03:01 PM
  #11
merky_marquis's Avatar
Originally Posted by yockit
Hi, it's the air pump, comes on to lift the rear and you my hear it release air when the car is on or off.
That's kind of what I'm thinking too.
OP if you can take a video that would help us quite a bit.
Also check and see if you have air bags or coil springs on the rear of the car, if someone has already done a coil conversion then their is no need to have the pump anymore
Old Feb 24, 2010 | 06:02 AM
  #12
JerseyTrueBlue's Avatar
That was one of the noises, I stated above^
Old Feb 24, 2010 | 10:16 AM
  #13
DefEddie's Avatar
The clicking noise is one of the blend door motors more likely.
It comes on at key on and at key off?
Sound like the blend door,it will default in both conditions.
Normally the door will just open/close,you hear a clicking because the plastic gear inside the actuator is stripped more than likely.
Common issue.
LuiV060807
Mar 7, 2011 03:23 PM
rcupak
Jun 16, 2009 11:49 AM
data6326
May 5, 2009 09:52 PM
kbsmom
Aug 13, 2008 06:30 PM
dmddfkc
Aug 7, 2007 10:11 AM
