1995 marquis ls...disable air suspension alarm
Old Aug 29, 2010 | 08:01 PM
baginz's Avatar
Default 1995 marquis ls...disable air suspension alarm
I removed the air bags on my 1995 Grand Marquis and installed coil springs and shocks.Even though I turned air suspension off,the air suspension alarm comes on after a short distance and stays on.How do I disable this alarm.......-: Thank You
Old Sep 10, 2010 | 01:04 AM
carlinjohn's Avatar
I would suggest you to go through the owner's manual.there it will be given how to do it.
Old Sep 10, 2010 | 01:39 PM
question for ya... did you unplug the fuses that run the air ride? i know there is one under the hood and iirc a relay also
Bulldozer's Avatar
Default Air Suspension
Have you tried contacting;
http://www.strutmasters.com
I think they would know how you do it, as they sell the coil spring kits.
I just bought a 2009 MGM which was a rental & I was surprised to see that it came with coil springs already. Seeing how you have now driven the car with both, was there a difference in how it rides and handles?
Old Sep 11, 2010 | 11:42 AM
baginz's Avatar
Thank you all.....removing irc/relay resolved the issue.
Old Apr 12, 2018 | 07:20 PM
Joe308's Avatar
How does the car sit and handle with the conversion kit? My car has the hpp pkg and I just put new kyb shocks all around right before my pump failed so didn't want to remove the air suspension, plus my air bags are still good at 72k miles.
BilalMGM
May 21, 2012 09:14 PM
couquis
Jul 4, 2011 09:26 PM
_Brian_
Jun 30, 2011 02:53 PM
mohamsghl
Sep 11, 2010 05:05 PM
Devil Boy
Aug 17, 2009 04:18 PM
