door hinge pins
Old 06-19-2009 | 11:41 AM
don1957's Avatar
Default door hinge pins
The pins and bushings are worn on the drivers side of my wife's 2000 cougar. When I went to the dealer to buy new ones they said that I had to buy the complete hinge for top and bottom $100 plus tax. Do anyone know where I can buy just the pins and bushings?
Old 06-19-2009 | 08:08 PM
conan312's Avatar
Check the net. If not, there is always the trusty old junkyard.
Old 07-06-2009 | 05:14 PM
93cougarboy's Avatar
I have a 93 Cougar with the same problem. I found the supplies at O'Reilly's auto parts for about $14. Hope this helps
Old 07-06-2009 | 08:51 PM
maxfax3's Avatar
I had a 99 Cougar here that I ran into the same issue with.. Luckily the local AP had an assortment of pins and bushings.. I found ones that were close.. Had to drill the holes in the hinges slightly, which was fine because they were worn too...
93cougarboy
10-15-2014 04:40 PM
searchlight4759
11-14-2013 11:26 PM
Quick Reply: door hinge pins
