2000 Grand Marquis code po304
Old Feb 7, 2012 | 04:37 PM
fixorrepairdaily's Avatar
Default 2000 Grand Marquis code po304
Code reads: cyl #4 misfire detected. I am going to pull #4 spark plug and check for any obvious problems with plug,wire, etc. Is there a way to test the coil or should i just replace it if i don't see an obvious problem with plug,wires? Thank you for your time, Chuck
Old Feb 19, 2012 | 12:24 PM
Rusty Lincoln's Avatar
If I'm not mistaken, your car has the coil on plug setup. A friend had this problem with his 01 Marquis a few years back. After two or three coils failed, he replaced all of them and never had another problem with misfires.
djr32978
Apr 25, 2013 12:06 PM
lukskywalker
Oct 25, 2010 04:32 PM
Briankos
May 28, 2009 12:47 PM
Mechamaniac
Dec 1, 2006 09:14 PM
lrb81372
May 10, 2006 03:43 PM
