2007 Grand Marquis steering wheel swap
Old 11-03-2009 | 08:39 PM
John Ryan's Avatar
Default 2007 Grand Marquis steering wheel swap
I have a 2007 Grand Marquis with the standard grade leather-wrapped steering wheel. I'm interested in replacing this with the leather-and-wood steering wheel with redundant temperature and audio controls.
Would be a straightforward swap, where all I'd have to do would be plug the new one into the wiring harness? Or is there a higher degree of customization between different harnesses, control modules, and such that would make this a tremendous hassle?
Any advice would be appreciated.
Old 11-04-2009 | 07:16 PM
If it's already wired for the audio controls, it would be a straight swap. If you have the factory stereo that's the same as models with those controls, it might already be wired that way and you'll just have to take the precautions with the airbag system so as not to kill yourself with an accidental discharge. If it's not already wired, you'll just have to source the additional harness for the temp and audio controls and then find where they plug in behind the dash.
murkeree_owner
07-08-2012 11:23 AM
searchlight4759
11-27-2011 01:13 PM
searchlight4759
11-27-2011 01:09 PM
nlengyel0001
11-25-2011 11:39 AM
ACM_Upholstery
12-07-2009 05:14 AM
Quick Reply: 2007 Grand Marquis steering wheel swap
