car has a minor shake
I have a 1989 Granmarquis 5.0 engine with platenium spark plug, no vacuum leaks, new wires, pcv valve,air filter,fuel filter,ac/heat works, but still my car has a minor,minor shake. What I mean is wentI stop at a light, the car is at an even stroke.The car is smooth as hell but after a few seconds the car gives me this minor shake. I know it is not much but I want my car to drive like a dream machine. It feel likeaminor uneven stroke. The car has alot of power for 159,000 miles. I plan to paint it and fix the interior. [img]smileys/smiley6.gif[/img]Any comments will be appreciated.
No, don''t touch the idle adjustment. No procedures yet. I just want to know if the engine feels like it wants to stall when you say it gives a "minor shake". Does the car have a tachometer? If so, does it flucuate during the "minor shake"? I would clean out the IAC (idle air control) for good measure. Can''t hurt. Let me know.
By a minor shake, I mean like a small uneven stroke.It is not that much of a difference, but I will attacked my tachometer and make sure it is up to stek. I might have to adjust the idle but that will be my last resort. Also, the IAC is a new one and so is the throttle position sensor. Their is no flucuation at all but the minor shake. Any more ideas will be appreciated.[img]smileys/smiley3.gif[/img]
Ok, Ihave clean the throttle body with carburator cleaner to remove deposit but the EGR i haven''''t yet. So , I will remove it this weekend and see what happens. I will get back to you with my answer as soon as Ido it. Anymore suggestions are appreciated and thank to everyone who is responding to questions.
Edited by: pdman
Cleaned out the EGR with carburator cleaner and it help a little. I lower the idle adjustment screw a little more at about 625RPM from 675RPM.To do this procedure you mustconnect an RPM meter andhave your car on Drive with the emergency brakes on.It is at the best that i think i am going to get it. So, Iam going to leave their and see how it responds.Thank you again for your responds.
