Idle Problem
Old 01-26-2008 | 10:27 AM
Texas_MGM's Avatar
Thanks for the advice. But where can I find the IAC? Also how do I go about and change the idle. I've had my Mercury for almost two years now. I'm just 19 years old, but I love working in my car. < src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-45";
urchinTracker();
  #12
Old 01-26-2008 | 11:44 AM
the IAC is locaed by the throttlebody area. here is a link to the site for the IAC. it is best to go with the Ford since the cheaper ones arent good for anything except paperweights.new from ford is around $150... so this is cheapest i know of for the Ford IAC.
http://www.rockauto.com/catalog/raframecatalog.php
the IAC is located under emissions as a Idle Air Control Valve... hope this helps.
Edited by: 87_Crown_Vic
  #13
Old 01-27-2008 | 02:19 PM
Texas_MGM's Avatar
Thanks for the help. I'll try and clean the IAC.< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-45";
urchinTracker();
  #14
Old 02-07-2009 | 09:36 AM
awh81781's Avatar
Sorry to resurrect an old thread, but I''m having the same sort of problem with my 95 GM. The check engine code says that there is excessive EGR flow, but I replaced it about 4 months ago when I cleaned all the passage ways and replaced plugs and wires. Could it be the IAC causing the engine code to say excessive EGR flow?
  #15
Old 02-07-2009 | 11:24 AM
possibly. you may want to check that the egr valve isn''t just stuck open too... or that the vacuum line to it has the proper routing and working check valves if any. if it''s an electric valve, it may have died. hopefully it''s still under warranty and you can just swap it out if it has died on you.
  #16
Old 02-07-2009 | 11:32 AM
awh81781's Avatar
Thanks for the info slymer. I actually misremembered (ha!) and I did not replace the EGR last time because it was still good. I replaced the DPFE sensor. I''m going to pull vacuum on the valve at idle and see if it runs rough. Am I correct assuming that the IAC has a direct line to the EGR? If so, I''m going to replace the IAC and see if that is the issue. There really isn''t anything left for me to replace I suppose! [img]smileys/smiley17.gif[/img]
  #17
Old 02-07-2009 | 12:55 PM
awh81781's Avatar
Ha! The EGR was stuck open. Easy enough after cleaning it out!
  #18
Old 02-08-2009 | 10:47 AM
w00t for the easy fix!
mustangdave
01-27-2011 11:08 PM
strivetodriveadc5
11-22-2010 11:55 PM
atl1983
05-23-2010 09:54 PM
cougarowner
09-20-2007 12:17 AM
Jons1989Marquis
02-09-2007 12:46 PM
Quick Reply: Idle Problem
