"check engine" light on and my mission...
Old 09-05-2007 | 03:47 PM
geri's Avatar
hey it's me again just to feed back on my "check engine" light on this mourning got up went to my mechanic shop now this is my dude he plugged in the scanner he got a code it's was that when i removed my air intaker i unpluged the switch from the sensor so that automatically trigger the computer to on the freakin' "check engine" light but then when he when to reset it i stop him now this dude got years working on cars more then i got breathing i trust him but i had a issue with the ford dealer well not with the dealer but more with the mechanics i'm not trying to take nothing from nobody or trying to star nothing he didn't reset the "check engine" light i went to the dealer now a hour and a half later sitting at the dealer shop i was told i had transmition problems that i was looking at buying a new one or a certified ford trans' now my trans' got no problem i went back to my mechanic told him what i did he turned of the "check engine" light didn't even charge me but i still bought a case of cold green hineeken that's why you should always know your mechanic try to start a nice relation with them because to tell you the truth and i know a lot of people agree to this some time you drive in to this named shops with a broken windshield wipers and drive out 2 or 3 thousand $$$ bill that why i always say get your hand durty ask question and get 2nd and 3rd opinions 'cuase sometime the problem it's no that serious and just to put it out there FORD dealer it's not the problem but this freaking mechanics that they think you are a freaking vegetable ya'll do the judging i already got my verdict...
Old 09-05-2007 | 05:14 PM
92Mercury's Avatar
It sure looks like you had a "a case of cold green hineeken" when you wrote this post. Might want to consider that many of us try to help, and we can only relate to what and how you are posting issues here.
If you already have your "verdict", then it's too late. If you want to dig a little bit, there are sometimes interesting things to find out.
The "check engine" light not only comes on when something out of the ordinary is happening in or around your engine, but also, as you already discovered, when other things are happening. On some cars (like the Dodge Caravan, see my other post), even the a/c is hooked up to the miracles of automotive engineering monitoring.
The electric manual of the GM states that you should have your vehicle checked if the light comes on, unless it goes off, which means the issue has been resolved (whatever that means) or the issue for the light to come on in the first place, is resolved.
Now, for example (referring to what experienced myself), if the light comes on and stays for a misfire, it was reset (in my case), and never came on again. The ignition probably had a hick up, no big deal if the light stays off.
I would always recommend to reset the system first, because of that. If the issue is resolved or not persistent anymore, fine. If the light comes on again, then investigating should be done.
My buddy's GM was red out, the code said "Converter lock up i/o", which the dealership stated as "inoperable". Now, the car place which red the code only got a "transmission" reading, not knowing what the exact cause was. The dealer was able to narrow and specify it down to the torque converter (the overdrive is engaged electronically).
We were able to solve the issue by disconnecting the electric connection to the switch on the transmission, clean it throughly (it's below the car, exposed to all kinds of debris, dirt and water), and reconnecting it.
I can not really believe that you already have a serious transmission issue on your car. And then, what exactly did the code say?
Why don't you drive the car with the system reset and see what is happening? Your fluid should be at the proper level of course.
It never hurts to get a second or third opinion. It's easy to spend money, it takes more time to ask around, but it is worth more to investigate and often safe a lot of money.
And what about adjusting your mission and post it in the corresponding forum. That's where you most likely find answers.
Greetings!Edited by: 92Mercury
Dobie1966
09-09-2014 06:30 PM
214shaft
01-03-2011 11:21 PM
olds97_lss
07-06-2008 02:12 PM
geri
09-04-2007 08:18 PM
damercga
12-31-2006 05:24 PM
Quick Reply: "check engine" light on and my mission...
