Squeaking noise when pressing the brake pedal
Old 06-18-2009 | 11:15 PM
AndrewSmith's Avatar
Default Squeaking noise when pressing the brake pedal
Hi, there:
My name is Andrew Smith and I recently got a 2001 Sable LS premium. The car works great. The only strange thing is when I press the brake pedal hard, I can hear squeaking noise from the bottom junction of the padel. It sounds as if the springs inside are lack of lubricants. The adjustable brake pads work fine. But is this noise an early symptom of some mechanical failure of the adjustable apparatus?
Thanks
Andy
Old 06-19-2009 | 08:04 PM
conan312's Avatar
My '97 Sable brake pedal used to squeak all the time. I would just spray some white lithium grease on the squeaky pivot point and it would be good for a few months and then it would need another spray. Probably where the metal meets the rubber on/or near the firewall.
Old 06-20-2009 | 08:44 AM
Thank you so much for the suggestions. I will have a trial today.
Andy
Old 06-15-2010 | 03:42 PM
briand's Avatar
I have the same problem also. I have a 2004 Mercury Monterey. Squeaky brake pedal.
stangcbr
05-15-2010 10:37 PM
DMCGEE
03-30-2010 12:48 PM
Mr Comet
09-13-2009 07:24 AM
Dock
06-17-2008 10:29 PM
Vanzilla
05-21-2006 02:32 PM
Quick Reply: Squeaking noise when pressing the brake pedal
